A few newbie questions. Trying to wire up my new Elk M1.
What is the best way to connect multiple wires (for example 10 smoke detectors SAUX) to the M1 panel. Jam all the wires into the screw down slot, or splice them before the panel and send a single wire to the panel? Does anybody use a punch down block for this kind of thing?
When mounting modules in the Elk enclosure using the circuit board glides is it possible to mount these towards the bottom of the can? It seems that only along the top of the can are the glide holes oriented to allow the correct direction of the top glide. What if I wantd to put an expander starting at the top of tha can and put a relay module below both on different sets of glides. I can't seem to figure out how to do the lower one.
Robolo
Robolo
