beelzerob
Well, here's how I understand the smoke alarms to work (I think).....
The smoke alarms are wired together, whether you run your LV wire to it or not. That's code. So, they're GOING to go off together. And if you look at the wiring diagram, you'll see a red wire that is labeled tandem...that's what causes 1 smoke to cause all other smokes to go off.
However, for the low voltage connection that we'd use to trigger a signal, I believe the difference in the CC and CX is what causes that to close. In the CC, that connection won't close unless that particular smoke senses smoke. In the CX, that connection won't close unless the tandem line triggers it.
So, to me the difference is that I'll be able to see immediately which smoke alarm triggered, even though all smoke alarms are blaring. The downside is I'll have to run firewire to every smoke, and then to my Elk panel. The cheaper, easier way is to just replace one smoke with a CX, and then you'll be notified that all your smokes are going off...but you won't know which one started the racket.
I definitely wouldn't interfere with the ability of the smokes to trigger each other. The inspector checks for that, anyway....and good thing.
Anyway, that's my VERY limited understanding of what's going on. But I'm STILL trying to just find a place to buy these things....
