When you generate the reversed polarity on a non-alarmed zone you will generate a fire trouble. I already told you that, it's the nature of what you are doing all the way down to the circuit board level and the integral diodes used to facilitate the tandem ring.
You may not care, but I doubt the AHJ will allow an active trouble condition to be generated and latch upon a valid active fire alarm. It's also covered within NFPA, whether or not the AHJ cites them is a different story, most I know of will want to see a functional test.
I put the economics out there. You're at $75 or so per detector + the module. Right at the cost within a couple bucks of an addressable detector and sounder base. Only variable is what the reset portion (if interfacing with a 3rd party) is, so 2 double monitor modules and you're done. Only item is how you get the information to yourself, which is easy enough via serial to whatever 3rd party device you're using, then it's not a question of compliance, since there's no requirement to identify where a fire alarm is occurring in a structure.
