Jay - I tried google, but failed - what's LMM? Local Monitoring Module?
Have you used a recent version of the ALC SceneTech software? Or is it redundant with the Elk?
Thanks for taking the time to post your review.
Sorry for the delay in this response. I've started it 3 times but never managed to finish.
First, a link:
http://www.onqlegrand.com/products/nav=a0f300000005ZJKAA2
HLC = Home Lighting Controller
- 1st module required for standalone installs
- Supports 1 branch and X-10
- Processor supports scenes and up to 3 more branches
- Pass-through serial comm to allow direct comm with switches
LMM = Lighting Management Module
- Event scheduling (time, event)
- Clock w/Sunset calcs
- Serial Port w/RTS(?) to toggle between HLC and LMM comm
- Links to HLC with ribbon cable
Home Lighting Expansion Module
- Adds 3 more branches to HLC
Serial Expansion Module
- Provides Serial port to HLC
- Not required with LMM
There are other serial modules (1 port, 4 port) for host-based control where the host does all the polling/commands/scenes etc. I have these but have since put them aside except for development/troubleshooting. It should be noted that the ALC physical interface is "almost" RS-485 but the levels are slightly off so an RS-485 device can "read" the commands but transmissions are ignored.
Regarding the SceneTech, I just updated to the most recent to verify functionality:
- Branch scanning and diagnostics (HLC)
- Supposed to have scene creation but not there (HLC), so the only way is via the switches (not fun)
- LMM Configuration for date/time/latitude/longitude
- LMM Rules
No, it isn't even close to Elk. While I have scenes created in the HLC all the real work is done in my Elk regarding rules (or via some python code I'm playing with to create eventlets). My LMM is only used for a serial port today.
However, at the same time, the Elk doesn't have access to all the scene buttons or taps/holds on buttons. My acronyms were wrong in my original post, this really needs a more intelligent HLC (not LMM) and some additional smarts in the Elk serial interface - Neither is hard, they just take time and somebody to have the desire for them.
One thing not mentioned here is what I would call "Installation Packaging" - for the ALC products I put in a 14" enclosure for _just_ the ALC-related stuff (HLC, LMM, Branch Expansion, Distribution Module and 8-port RJ45) with appropriate cabling to the Elk enclosure, branch hubs, switches (for local dist module) and Altronix 12VDC PDU/Distribution panel. I've opted to not use wall-warts and instead use a 10A 12VDC PDU for everything. I'll post a picture in the next day or two.
Any other questions, ask here or send me a message. I'll try and be more responsive.
Jay
