tmbrown97
Just to play devil's advocate:
Which method you chose is matter of preference - I'd run conduit to TV locations and category or maybe even the mixed cable DEL suggests to the rest - but, the cost of the cables is a small price - the cost of the terminations is what'll really get you.
In my last house, I ran 3x Cat5e and 3x Coax to each wallplate; 2 wallplates per room on opposing walls. Infinite flexibility - since coax can be used as RCA and Cat5e can do most anything - but I didn't use much; in this house it was a pre-wired 2-story; best I can hope for is a single Cat5e per room and none at all in some key living spaces; but I've only bothered to run 2-3 more Cat5e wires - the rest of the places I made due with what was present and I'm surviving.
In some states that's strictly against code - at least in a commercial setting. In fact, in CA that's not allowed - anything not terminated at both ends must be removed.You don't need to terminate what's not connected. Leave it in a rack, can, trough or what have you until you need it.
Also varies by area - I see a lot of that in AZ, but I never see it in CA or WA unless specifically penetrating a fire break.Conduit is the standard in office settings to the point where it is probably 99.99%. The conduit runs up the wall into the ceiling space where a single sweep 90 turns it horizontal above the drop ceiling.
