apostolakisl
I am trying to connect a remote thermometer to my CAI Webcontrol. I purchased several of the recommended DS1822 sensors. Hooked directly to the board, they work fine. But I would like to locate one about 40 feet away. I connected it with CAT5, rebooted, and the sensor doesn't show up in the menu. In fact, it caused the sensor still directly connected to the board to disappear from the menu as well. I ohmed out the wires and all is good. I removed the sensor directly connected to the board, and still nothing. I replaced a single sensor directly to the baord and it works again (the same sensor that wouldn't work at the end of the wire).
So, in short.
1) All sensors work when hooked directly to the board.
2) Neither sensor works at the end of 40 feet of wire.
3) When a sensor is attached at the end of 40 feet of wire, it also makes the sensor directly attached to the board vanish.
4) I used CAT5e wire and the individual strands ohmed out fine.
5) And yes, I double and triple checked that I had the right wires connected to the right things.
6) I did reboot the unit each time I changed something.
I am assuming that the CAI doesn't have enough juice to drive current down the wire to the sensor?
I am hoping someone knows what I need to do to get a temp sensor sending data from 40 feet away.
So, in short.
