Anthony A.
Has anyone encountered this behaviour with the GE version?
You didn't say what type of receiver you have. With a GE receiver, I have never seen a signal strength indicated. Must be only the HAI receiver provides that. Also a weak signal should cause any false alarms, but you will get supervision alarms. Also, if you are using GE sensors, there are several good signal repeaters available. All you do is mount these mid-way between the weak sensors and the receiver and provide them with power. No other connections are required. I added one of these and have never had supervision error since.fcroisetiere said:I'm still getting a lot of RSSI=0 and false alarme, I will try to relocate my receiver tomorrow and see if it does help, since the receiver is a treated as a console, may I connect the receiver to a console instead of the panel? that should give me a chance to mount it hire without making hole in every wall of the house...
Sorry to hear that...fcroisetiere said:I'm using HAI, still got RSSI 0 after relocation, only 1 of my 3 sensors is having false Alarme...
