Slartybartfast
Hello everyone,
With the cold weather arriving in South Australia I've just noticed an oddity with our OmiPro II. If the heating is on when we set the alarm (Away) to leave the house the heating will turn off and the heat and cool setpoints changed to 16.9C and 29.5C respectively. When the alarm is turned off the heat and cold setpoints change to 23C and 25.5C and the heating will turn back on if of course the thermostat is below 23C. I've looked and can see no programming that could account for this (using PC Access).
I'm wondering if there is a "default" energy saving mode that I need to change, but have not tracked it down. The heating/cooling is controlled with a HAI Omnistat2 controller. The system has been working well in the past although I did loose network access late last year and had to restart the system (which fixed that problem) and at the moment I am also getting a battery trouble message with new battery's.
I have an OmniPro II with 2 expansion enclosures, 17A01-2 zone expansion and 19A01-1 relay board.
Has anyone seen this behaviour?
