gogrixdale
I’ve been HA addicted for about a year and using for about 3 months.
So far so fun …but many dollars and many hours later I’m stuck.
Problem:
UPB Link (LRNormLvl) works fine when called from the M1 and ElkDroid. But as soon as I use the rocker of a switch (US2-40), to transmit the same link, the PIM will no longer respond. To any command. It’s as if the ELK and PIM (M1PCSPIM) lose communication.
Tried:
Calling the UPB link from a rule while in this “disconnected” state does not work either. No status light activity on PIM. *This removes ElkDroid from the suspects list.
Tried setting the Receive Sensitivity at the PIM to Low. No Change.
(Re)Exported/Imported lighting config. No Change
Misc. Info:
Switch transmits link as Top & Bottom Super Rocker preset.
Switch also receives link and operates local load.
Link operates (2) US1-40, (1) US2-40
Unacceptable Solution:
Unplug the PIM or reset the M1. PIM operates normally until link is initiated at the switch again.
gG
Long time lurker, first time poster.
Problem:
Tried:
Misc. Info:
gG
