Hello All-
This is my first post on this board, and unfortunately I'm not sharing good news. After months of researching, I decided to go with UPB for the new home we're constructing next door to our current house. I received my first order of about a dozen switches (mostly SAI US2-40's) installed 3 of them in the new house and fired up UPStart to test it all out. The first screen that popped up told me I had severe noise levels (>28) that will likely prevent the system from working. The noise was so bad, I couldn't even create an initial network, let alone see any of the switches. The house is in its last stages of construction and is unoccupied, so although there aren't many appliances running, there were several carpenters there and I figured maybe some of their tools could be causing the problem.
I came back after everyone left at about 6pm, shut down all the flourescent and low voltage lights, and tried it again. Althought the noise dropped from 28 to 22 with the "noisy lights" shut down, it is still severe and unusable. I decided to see if I could isolate the circuits generating the noise, so I took my laptop (running on batteries, no AC power supply) down to the circuit breakers in the basement. It's a big house (about 8000 sf), so there is a main panel, 2 subs, and 6 "subs of subs". There is also a generator with an automted transfer swich. I plugged the PIM into the outlet coming off of one of the subpanels, opened the UPStart Noise meter, and started flipping breakers off. The initial reading in the basement was 18, a little lower than the main floor. For the most part, each shut breaker had no effect on the noise level, but to my great suprise, 3 cirucuits actually caused an increase of about 2 counts each in noise as they were shut off. By the time I was done, I had every single breaker in the entire house off execpt for the outlet the PIM was plugged into (it is the only item on that circuit), and my noise level was now 22 instead of the initial 18. I also completey shut down the generator all of its circuits, with no impact either. I'm assuming I have a major external source of noise.
I came back the next afternoon (the trades were all there with their saws running) and now, for no apparent reason, the noise level was down around 6. I was actually able to create a network, configure the switches, and create some links (required a lot of retries). The link was working about 4 times out of 5 immediately after I set it up. I came back around 5pm (after everyone left) and the links did not work at all; fired UPStart up again and noise is back to about 20.
I tried this out in my current house next door and got similar results; severve noise most of the time with windows of barely usable quality. Obvioulsy, this is not even close to workable.
I've heared about these prototype and/or home built "whole house filters" that may help with external noise sources. Does anyone have any knowledge or experience with these? I'm a little reluctant to possibly throw good money after bad if this is a low probability fix. Any other suggestions on dealing with external noise (except poking around inside all my neighbors houses!) would be greatly appreciated. I'd really like to make the UPB work, but based on the results so far I am not optimistic and am seriously considering buying a few Z-wave switches to try out.
Thanks everyone.
Thanks everyone.
