Dean Roddey
I mentioned the performance issue because I thought that video was part of the mix. You'd be hard pressed to do multiple streams of that, assuming RDP event supports video playback at all.
What is a 210? Just an updated 110?dgeffs said:The 110's are very hard to find and I was planning on purchasing a 210 at one point but my project got shelved for a while.
My thinking was that I would use machines that I was retiring from service in some primary role to be airpanel machines. Even if I only do one machine per panel it would essentially be "free" hand me down hardware.Dean Roddey said:The Viewsonics are RDP clients. RDP can be used, but has many shortcomings. And if you want to support more than one, not only do you need a fair amount of horsepower on the back end, you need to pay for some sort of solutoin to allow for more than one RDP session at once, either by using Windows Server or buying one of the third party programs that allow for that. So it also adds expense.
If you are willing to buy used, you might still come out ahead. But, overall, I'm not sure you come out better than just buying a UMPC tablet.
Rupp,Rupp said:The hack for XP works fine and allows 10 connections.
I am using 6 Airpanels V150P and MainLobby, and as far as I am concerned it is running great.upstatemike said:Thanks for the link Rupp... lots of good info! I see Paul is using the 110 model with MainLobby with good success. The Airpanel apparoach probably has better longevity since I could upgrade the host cpu without replacing the screens.
Anybody else using the airpanel as an interface?
I would be interested in more than 3 also.mwhistle said:Rupp,Rupp said:The hack for XP works fine and allows 10 connections.
When you get a chance, could you let me know what setting you're adjusting to get that many connections?
I'm only able to get 3 concurrent sessions (console + 2), and I'd love to get a couple more if I could.
Thanks!
My concern about the 150s is they dont do RDP while in the charging dock. I am picturing these being used while docked most of the time and only sometimes taken out for mobile use.deranged said:I am using 6 Airpanels V150P and MainLobby, and as far as I am concerned it is running great.
The screens could refresh a little faster, but they work well and the Wife loves them.
StevenE
I think of it this way. UMPC or other touchscreen based 'clients' are part of a distributed processing system. They all handle their own part of the load and take the burden off the server. Whereas a CE based 'thin client' is just a front end to a server. Like David said the server and OS has to be able to handle the amount of clients connected to it thus making the server more expensive. Some applications that can run under CE are out there but that limits your choices. The UMPC looks like the right choice for those that want to run Mainlobby or CQC front ends.DavidL said:CE is nice for fast boot. But, you can't run a PC application on it which really limits it's flexibility. That is what is nice with the UMPC.
You can run RDP from CE to a Windows Server for multiple connections, but then you have the expense of the Server OS.
CE devices are typically very low CPU compared to a PC / UMPC. But, because of that, good battery life typically.
If you have a specific purpose for it, and that runs on CE, then good to go. Otherwise a boat anchor.
