Got this in an email on Tuesday...
If you use or install the HAI / Leviton OMNI, then you should know about a new initiative from Powerline Control Systems specifically to help OMNI installers use PulseWorx UPB for lighting control. Complete details of this new initiative are now on the PCS website.
First, we have made changes to the UPB configuration program UPStart, that make it easier to configure PulseWorx devices to work with the OMNI. Look for those changes in version 8.2, downloadable from the PCS website.
Second, we have new application notes for OMNI installers that show how easy it is to integrate PulseWorx with the OMNI. These are available in the PulseWorx resources section of the PCS website.
Third, now available is a new adapter to use the PCS high-power double-transmitter PIM with the OMNI.
The PIM usually installed with the OMNI has a special connector that plugs into the OMNI board, so it wasn’t possible until now to use a PulseWorx PIM. Using the new adapter, the new higher power PulseWorx PIM-R can be used with the OMNI.
With the PulseWorx PIM, transmit signals are 50% stronger than older model PIMs. As the PIM connected to the OMNI is the single transmitter point that must be heard by all UPB device in the installation, this ensures a higher quality signal reaching all the devices.
In addition to the higher transmit power, the PulseWorx PIM also has a setting for high or low sensitivity. This setting helps reduce noise problems in installations with good signals but a low-level power line noise issue.
The sensitivity setting can be adjusted using UPStart and is stored in non-volatile memory. This means that you can adjust it with UPStart while the PIM-R is connected to your computer, then power down, and connect to the OMNI using the Adapter.
To find out more about the OMNI PIM-R adapter, we have an application note with all the details.
Personally here have not had issues with the HAI PIM and HAI (PCS) dual phase repeater.
