Haiku Remote camera viewing
kevc66
Hello,
First timer here.
I need some help with an issue. I have an Omnipro system installed and I am having problems being able to view the installed cameras remotely. They can be viewed locally in the Haiku app and on the Omnitouch 5.7e, but cannot be viewed remotely. I believe I have the ports properly opened. I think the setup IP address to view remotely is not correct.
The system is an Omnipro with firmware at 3.11. I have an Everfocus (ECOR264D2) dvr networked into the system. I can view the cameras locally on both the Haiku app (version 3.88). I also have both the Omnipro and Everfocus dvr using DYNDNS hosting. Attached to the dvr are four Speco Intensifier 3 cameras.
I have tried aiming the app at the host name of the dvr. This doesn't work. I know this isn't that difficult, but I must be having a brain fart.
Any help would be greatly appreciated!
Thanks in advance
Kevin Carraway
You will need to forward the camera MJPEG ports via your router. Then use the DynDNS address and appropriate port (as forwarded in the previous step) in the camera configuration in Haiku.
For example if your DVR is on myhost.dyndns.org and on port 8001 you would enter it in Haiku as:
Code:
http://myhost.dyndns.org:8001/path/to/stream.mjpeg
