drvnbysound said:
drvnbysound, on 11 Feb 2014 - 21:53, said:
Personally, I'd probably never attempt to hard wire for doors/windows at any other time than new construction. Wireless sensors are cheaper than the amount of labor it would take for me to do it.
If your basement is unfinished, it's probably not that bad for most places. I wired everything I could in my last house. That said, $25 for a MicraG sensor is worth the time/labor savings in a lot of cases. If I did it again, I would only wire things that NEEDED to be wired, or things that were easy. For things that could be wireless and required any kind of hassle, I'd probably just get wireless sensors.
I believe there's a wiring guide somewhere on this forum. When I've done all of my wiring, for equipment, I use:
- One of those long flexible drill bits. They are 4 or 5 feet long and about $25. Home depot has them.
- Fish tape
- 3 piece glow in the dark fiberglass rod
- sheetrock saw
If I've got a location that's difficult, sometimes I will cut strategically placed holes to gain access. But I cut them the same size as a remodel outlet box and put a blank plate over them when I'm done. For example, if I'm going from a wall into a ceiling, I'll cut a hole near the top of the wall to drill the top plate, and another in the ceiling for access from the top to fish the wire. At the bottom of walls, you can take off your trim and cut a hole that would be hidden by the trim when you put it back on.
Another thing I do is I get those plastic access panels that have a frame you glue in and then snap the cover on. If there's an area in a closet or somewhere that's absolutely not normally visible, I cut a 15x15" square hole in the wall for access, and then put the panel in when I'm done. These work great for closets that border duct chases from basements to upper levels.
There's another thing called a Magnapull which is pretty cool. It's a magnetic wheel and a metal "bullet" that you attach your cable to. You put the bullet in the wall and use the magnetic roller to pull the bullet up the inside of the wall. I don't have one, but I want one. I think they are like $200 though.
I used these methods to put about 15k feet of network and alarm cabling in my last house. And nearly 10k feet in the house before that, and that house was completely finished.
My current house was wired like crazy... in 1995. So a lot of the wiring is outdated, mostly for AV. I'm running network cable now, wires for audio distribution keypads, and some water sensor wires. What I can do wirelessly, I do wirelessly. But unfortunately, some things need wire.
To be honest, I'm sick of running wire. I still have to wire for cameras, and I'm really not looking forward to that at all. I did just buy about 100ft of 1.25" Interduct on craigslist, so I'm going to pull that through areas that are "difficult" so I have an easy path in the future if needed.
