Hi - Spent the last couple of days researching and trying to decide on most reasonable approach:
▪ HAI OmniPro II controller
▪ Wired ACL lighting and motion sensors
▪ Omni Consoles 33A00 (no video touchpads )
▪ Russound Music Distribution
What I want to add:
Outside
▪ Front door Intercom (Cat5) (Channel Vision DP-002C with TE-111) (was wired for a Holovision - look like interchangeable products?)
▪ 1 Front door Camera (Coax) (2way audio) (~50 ft night vision)(Will be using a ceiling camera, instead of a camera in the intercom, so can see larger area of front yard, in addition to person at front door)
▪ 2 Back Yard Camera (Coax) (~100 ft night vision)
▪ 1 Garage Alley Camera (Coax) (~50 ft night vision)
Inside
▪ 2-3 Main house cameras (table top - coax or cat5) (2way audio)
▪ 1 Guest house cameras (ceiling coax or can be table top - coax or cat5) (2way audio)
Interfaces
▪ Mostly view on iPhone, iPad
▪ Web Site option nice but not needed
▪ View on TV also nice (DVR/NVR would be in basement and wiring options to Den are Cat5 or Coax)
How used - See / Speak to whom is at front door
▪ Intercom (when in house) - I can pick up any house phone to talk
▪ Camera (when in house) - iPhone with 2 way audio, or view on TV
▪ Camera (when away) - iPhone with 2 way audio, or on Web
▪ This Front door camera would want a bit nicer video and audio since using more often and mostly would want a very good/reliable iPhone app
Security
▪ View and listen in on house (if HAI calls me on a breach)
▪ These cameras don’t have to be state of the art since not using a lot
▪ although 2 back yards ones would have to reach 100ft at night and might be nice to be able to rotate position from iPhone (lower priority)
Questions
▪ Type and Brands of DVR/NVR systems recommended to accomplish the above?
▪ Cameras Brand/Models recommended?
▪ Can the HAI OmniPro II system and cameras be integrated so motion detection from the camera at the front door can trigger lights to come on? (Or is it simpler to use another HAI motion sensor here to trigger lights?) (Will most wired motion sensors work or does it need to be HAI/Leviton brand?)
▪ The HAI/Leviton DVR and cameras seem overpriced – any advantage to using them?
THANKS!
- Analog system for exterior and interior (Looks like most cost effective, although for interior cameras, I only have the option of using tabletop cameras – do they make analog tabletop? How about using dome cameras inverted?)
- Hybrid DVR to connect both analog and IP cameras
- Analog system for exterior and use separate IP camera system in the house. (disadvantage – have 2 unintegrated iPhone apps to use)
What I want to add:
Outside
Inside
Interfaces
Security
Questions
THANKS!
