Unless specifically mentioned, all wire will homerun to the same location in the basement (directly below mudroom).
Connections on floorplan are to be wired as follows:
1)Speakers will be wired with 16/4 wire. There will be a separate run for each room. The run will travel first to the A/V keypad or touchpad location, and then to the speaker. In rooms with 1 speaker, the run will terminate at the speaker location. For rooms with 2 speakers, the run will travel to the nearest speaker, add 1 ft of slack, and then travel to the other speaker. In the great room, 2 16/4 runs will be required for the 4 speakers. Those runs will first travel to the video location on the wall between the great room and the den, and then down to the wiring closet.
2)Temperature sensors will be wired with 22/2 wire.
3)Window and door contact sensors will be run with 22/2 wire. Wire shall be run to the top of the window or door frame.
4)Touchpad or A/V Keypad locations will be run with a combination of Cat5 and 18/2 wire. (Note: Cat5e wire can be used if the cost difference is nominal).
5)PC Network runs will be with 2 separate Cat5e.
6)TV Outlet runs will consist of 5 separate RG59 coax wires and 1 RG6QS wire. The RG59 wire must be “precision videoâ€, 20 solid BC center conductor, 100% foil, 95% TC braid.
7)Smoke alarms will be wired with 22/2 wire. This is only for secondary notification of an alarm. The smoke alarms will adhere to all code requirements without any need for the 22/2 wire. The actual smoke alarm to be used will be the GC 350ACC (or similar).
Connections not pictured on floorplan:
1)4 QSRG6, 2 Cat5e, 18/4 to attic, at attic access location.
2)Doorbell wiring to run from front door button location to wiring closet, then up to doorbell chimes.
3)1 Cat5e to thermostat location.
