marvell plug computer
I was reading about that, specs look very interesting, but I can't think of what I would use it for, either because of price or the odd form factor.
Cool device. I'm surprised by the low price. As this technology becomes cheaper and cheaper I hope it starts being manufactured into appliances and other normally unconnected devices in the home. That would be sweet...
As it stands now, I wonder if this device could be used as an Asterisk server or homemade NAS. Maybe it could even run a stripped down version of MisterHouse or other software controllers.
If there was a USB touchscreen monitor out there, maybe this could drive a screen on a wall for your automation system. I know Samsung has a monitor that does video over USB (at least for your 2nd and 3rd monitors on a single PC), but I'm not aware of any USB monitors or touchscreens without any VGA/DVI requirement.
EDIT
I just noticed this thread discussing a touchscreen USB monitor... maybe it could be connected to one of these Marvell computers?
thought i would bump this thread as i just picked up a seagate dockstar (from here http://goo.gl/FO6M ) for $25. the dockstar is a derivative of the plug with gigE, 3 usb ports but only 128MB ram. i disabled the pogoplug software on it & used this link http://goo.gl/cXGh to install debian onto a 4gb usb stick.
in the 3 days since i got it:
- set it up as a IP contact closure device using a dealextreme $5 gamepad & hacked some perl from xPL-perl to send the input changes via xPL
- set it up as a bluetooth proximity zone with a $2 bluetooth usb dongle & more hacked perl from xPL-perl
- installed a webcam (only got 1 of 3 webcams to work) and motion ( http://goo.gl/JC4Dx ) for webcam motion detection
- installed sphinx (http://goo.gl/RZ7n ), an open source VR package, and have gotten voice recognition working as well
- there is a native binary for a squeezebox emulator ( http://goo.gl/tWYJH ) so it works as a headless squeezebox player
i ordered a couple more units today. i plan on using one to 'upgrade' my public webserver from a linksys nslu2. the dock is about 4.5x faster and only uses 3 watts.
Think I can get sound to work? I have a little project in mind which would require a low powered linux appliance, supporting audio out, but cost has been an issue so far.
I do like the idea of using these around the house as BT proximity detectors, you could actually create a tracking system assuming distance is decent.
Wow, I've got two of these dockstars...and actually, it has 4 USB ports. The top one just needs an adapter (1 bought 2 of them on ebay for $4 including shipping).
Code:
damage, what OS did you flash on there to mod it?
edit: sorry, I just saw your link you posted about getting Debian on there!
I wanted to get rid of the stock OS, just because of it's calling home. Right now I just tell my DHCP server to assign a non routable gateway to the box, so it can't get out of my local network...but I'd like to get something else on there.
I also like your idea of using the BT stuff. I've been wanting to do something like that for a while, but haven't had a good way to remote a BT dongle.
I'd really like to try this out.
So far, I've only used them as USB drive extenders (I put 3 of my USB drives on there and use them for backing stuff up).
--Dan
i used it with a usb soundblaster and it worked flawlessly. was playing mp3s with mpg123 and the squeezeslave works well too. there was one glitch i ran into after installing mpg123 (high cpu) but i found a solution quickly (link in my blog post http://goo.gl/nWSVc )
i forgot about the top one since it has a mini-usb connector. good find on the adapters. i ended up using a $2 usb hub i had lying around.
this is an ideal application for xPL since it's lightweight and can run on a variety of platforms, but people are reluctant to use it.
the debian install was really straightforward. installing apps is a little more work as you'll run into dependencies they need and have to install those. but the apt-get package manager handles it well after you figure out what you need.
I think most users find xPL too intimidating. A BT based triangulation project might be all thats needed to really kickstart it ;)
edit: I just ordered one, for various experiments. Hopefully I can find something similar, this cheap, in the near future.
I think most users find xPL too intimidating. A BT based triangulation project might be all thats needed to really kickstart it :P
that's too bad because there's a bunch of really useful xPL apps out there (especially mine ;) for example, i recently wrote an xPL interface to google's powermeter ( http://goo.gl/N918 ) and an app to check gmail accounts and send short emails through them without the need for an ssl wrapper like stunnel ( http://goo.gl/RhBD )
on a side note, i posted a link to this topic over on the homeseer board's discussion of the plug and it was deleted ;)
damage,
I've considered getting xPL installed on HS for a long time. Are you using this with HS? It appears you are a Hs user...but not sure if you are using the xAP server with Hs or not. If you are, which one are you using? The MCS one?
--Dan
damage,
--Dan
not a HS user, but i do go over to the board to get ideas...and posts deleted :) i don't think there's even an xPL plugin for HS and not sure if any of the xAP plugins talk xPL too. however, i have written an app that contains a scripting engine and talks xPL and xAP so it should be trivial for a HS user to write a script in it that uses the HS activex object allowing access to whatever HS exposes.
