Either by a over sight or design error, SmartLabs produced products with a INSTEON logo that never met the original design specs. Now consumers must pay to fix that mistake. It also makes creating useful software a bit of a nightmare. You can bet if my Z-Wave devices did not meet the Z-Wave specs they would go back as defective merchandise. Oh well, I guess you are either happy or not with the current state of SmartLabs business practices.
Just because the Insteon protocol HAS all these features doesn't mean every device has to use them. What exactly about the existing switches isn't working as advertised, or will fail to work down the road? As for useful software, there is plenty of great software that supports Insteon. As a matter of fact, I see more software supporting Insteon than other lighting controls. I'm not saying it's an easy task to support Insteon, but I hear plenty of issues writing drivers for Zwave as well.
It is sort of like buying a 300 horsepower car only to later find out it is really a 90 horsepower.
Not at all. It's like buying one model Honda with a 4-cylinder engine, and complaining because you found out that Honda came out with a 6 cylinder version the following year, and feeling like you've been screwed.
Why are LEDs on keypadlincs set so if you change the factory brightness setting you can never get it back even with a hard reset?
Is this correct? On my KeypadLincs I can choose between two different brightness levels, and go back and forth at will. Is there some other adjustment I'm not aware of?
Why can't you set the local ramp rate or X-10 address of an Insteon device remotely via software without having to physically touch the device?
I believe this can be done through PowerHome, but I could be wrong.
I'll add these questions:
- Why do a fairly high percentage of switches come in with problems? Usually I can just FEEL that a switch is going to give me problems when I take it out of the box. Press the ON/OFF a few times, and some switches just don't feel as solid or have a good click like others do. These are things that should be found at the factory .
- Why did they have so many issues with varying LED intensities and color tints? All of my later switches have been OK, but for a while some switches would have a slight bluish or greenish tint and look silly next to others. Also, I hope they stabilize on the LED brightness - I think the current level is perfect. With something like light switches, consistency should be a high priority for SmartHome.
