Neurorad said:
I downloaded the Amazon Cloud Player software to a networked PC, and viewed all the albums I have bought from Amazon. I then downloaded them, using the Cloud Player software as mp3 files, and now I'm using Music Port Sync to copy them to the MPS4.
Newbie to the board. And...fellow doc. Seems none of us can stop working (although this is much more pleasurable).
My main project now is to automate our NuVo system. When we moved into this house 6 yrs ago, it was pre-wired with a NuVo Concerto (not Grand). It's a 6 zone/6 input system. Also have a T2 tuner. All 6 zones are used and wired by keypads in each room. It works fine - sound is great. Have set it up with the inputs we use the most. Kids can use it - put it on, control the volume, change radio presets, etc from the in all panels.
Problem is - the techie in me wants to control the system without getting off of my couch and touching the keypad or getting up to grab the remote and find some direct line of sight route to shoot the IR remote at the keypad. I'm trying to find out if I can control it via wifi (ipad/iphone/laptop/droid). I want to be able to turn zones on/off from the comfort of my couch or outside (have 1 outside zone but the keypad is inside). I've searched and found many suggestions for the Grand Concerto, but not the legacy Concerto system. I'd prefer to not have to upgrade the system to the GC. Not discussed at all is this app which I found (not allowed to post links...yet, but you can find this in the Apple App Store; look at the figures especially the 3rd picture):
TheConductor by BuildThings
It says that it works through a spliced in device on the Nuvo net to convert the Cat5e (inputs from all keypads) to serial with a wifi interface. It will identify the IP address of the keypads and then do an automatic setup to create a wifi remote control.
Found a wifi serial to IP bridge: Global Cache, IP2SL
This can convert the Nuvonet signal on the cat 5 to the serial port interface and has wifi control.
So...my first question for the forum is: should this work with the Concerto? If not, any other suggestions? Hook up a wifi to IR converter and put it over the IR receiver on the keypad? Problems with this (besides my wife's objections to the decor) is that I don't think it is possible to send a signal from one keypad to activate another.
Once I solve this, will move to next project: being able to control the source input and access/control iTunes input to each zone. I don't need to have metadata on the keypad - would never walk over specifically to learn of the song. Presumably will be able to access this on the tablet/phone. Have thought about a Sonus Connect as one of the inputs which I can control wirelessly and should access my iTunes server. This is stored on a Netgear ReadyNAS Pro6 which runs a Firefly iTunes server (accessible on the network) and I'm assuming will be accessible by the Sonos.
Thanks much!!!
Other equipment:
Roku 2xs (x2) running Plex to stream movies from the server.
