Dan, good news. I like the map and how it works with the TS.
Mostly lately attempting to write the ZM install / tweaking / XAP post on HS. Its kind of difficult as sometimes will write and by accident will delete or mess up the formatting making it seem to be taking forever. I am also trying to write it such that its easy to understand.
Michael,
Reading what you wrote; sounds definitely like its relating to how you have security, pc firewalls, groups, etc set up on your network. I see a reference to "homes" - W7 networking "stuff". Microsoft / W7 is redefining what home networking should be like. They want to make it secure and plug n play; which is a good thing but not for what you want to do with the dockstar at this time.
For moving just a few MB's of files stick to using WinSCP.
Samba Wiki
Read the Samba Wiki relating to using it. My playing with it lately was on the NMT's to get the fastest thruput moving Gb's of data. I was able to tweak it on the NMTs such that the fast transfers are still only OK. (GB's of files).
I am currently playing the the 3rd Dockstar; reconfiguring it per what I've written. I've had no issues with Samba (setting it now at least maybe 5 times). In the last couple of days I've been tweaking xwindows on it and now playing with the mimo touchsceen pieces of the linux mimo drivers as I have it working but have to figure out best means to calibrate the Mimo touchscreen.
I would though recommend using Webmin; both relating to speed and "plugnplay" pieces. I can see the shares fine from all of the rest of the computers on the network (W2003, XPSP3, flavors of Linux and W7).
In the last few days I've been setting the boot/reboot of the dockstar to do clean boots. 3rd build is on a 4Gb stick and its been fine. Not paying attention I decided to do a Gnome GUI install with all of the bells and whistles; walked away from it last night. Looked a couple of hours later and noticed I had totally filled the stick and it didn't complete the install. It still boots up fine so this morning imaging it back to a 16Gb memory stick. The following Samba configuration file was created by Webmin. (calling it DS1 of 3 right now)
Code:
# Samba config file created using SWAT
# from UNKNOWN (192.168.244.233)
# Date: 2010/11/18 05:02:50
[global]
log file = /var/log/samba/log.%m
guest account = guest
socket options = SO_KEEPALIVE SO_BROADCAST TCP_NODELAY
admin users = pete, root
obey pam restrictions = Yes
write list = pete, root, @sambashare
guest ok = Yes
username map = /etc/samba/user.map
winbind trusted domains only = Yes
dns proxy = No
netbios name = ICS-DS1
netbios aliases = ICS-DS
writable = yes
server string = %h server
