Ok,
I've been working on two projects. One being Touchscreens for the house. The second...well, this!
Why not blend them??
The reasoning:
I finally got to the point in my install for the touchscreens where I ran everything on the test-bed setup. Everything was 100%. So, I then imaged the server's OS drive. Then I started installing all the hardware and drivers necessary.
I'm using a USB Touchscreen with a UV12 Plus+. Worked WAY beyond what I thought it would on the testbed PC. The thought it, I extend the Server's video with a USB video card, then remote that video to the touchscreen. Since the touchscreen is USB 1.1, and you can cheaply remote VGA + USB1.1, seemed like a great way to put touchscreens around the house. Especially since it seems pretty future proof. My cost per screen will be about what it would be with buying a cheap iPAD (maybe less), BUT to upgrade my system, I change out the server. bingo, the WHOLE system is upgraded. Instead of replacing each screen with something new. Plus, installing something new, like silverlight, or the next "flash" type thing, or HTML3 support is as easy as upgrading just my server.
When I moved to the Server, the driver wouldn't load. Win7 issue? I thought so. I put Win7 on my test bed PC. Tried again, worked flawlessly.
After a week of looking, I found it's because the DisplayLink driver is not allowed to work with a non-certified Win7 driver. My server has an ATI Rage XL video card built into the motherboard. There is no Win7 driver. NO AGP, only PCI slots...so, I can't even test with the extra video cards I have laying around the house.
So, in my frustration, I did a search for UV12 and Debian. I've become a bit familiar with it due to this project, and I thought, if I had to try a virtual box, or VMware something or other, make it something I'm playing with right now.
USB Video Card on Dockstar
So, I took a look at the Linux HSTouch client. It seems that it will run on anything that can run Mono. It also seems that the latest kernel on Jeff's site (the guy we pulled the Dockstar image from) as the DisplayLink drivers built into the kernel (read that link).
So...I have 3 of these Dockstars, why not put one behind the USB touchscreen (I found Linux drivers for it), then I run the HStouch client on the Dockstar, with my USB Touchscreen and the USB Video card!!
Wow, GREAT solution until I can get a reasonable PCI video card for my Server (again, it's the upgrade factor). I've seen some PCI video cards on e-bay, I'm not convinced they are actually PCI (probably PCI-E), but they look dual head, which following how I'm extending the video, saves me from having to buy 1 USBtoVGA adapter...
Pete, did you ever get the Linux HSTouch client working? I saw you were going to try it on some Nokia 770 or 800. If I can draw on your experiences, that would be great!
--Dan
