drozwood90
Dan,
Thank you for the details about your touchscreen configuration. For the older TS's in the house I utilize the wired PIR sensors to wake up the screen and for the Mimo I created a "push button" to sleep the computer and I just touch the screen to turn it on. I am having problems though that the Mimo drivers are very fussy relating to the powered Hub. Sometimes working and other times I have to reboot and unplug the USB cable and plug it back in.
Not sure if its worth the effort of 1 USB cable versus three VGA TS cables. Same thing you describe happens with the Mimo Monitor where it doesn't see the TS piece. I have to go in and tell it; then I have to readjust.
So are you thinking of using the JTAG DTR pin to power the screen?
DTR = Data Terminal Ready. It's just a handshake line for the serial port, when used with Hardware Flow Control. You can assert it separately from the rest of the lines, so I would tie that into a small optical relay and tie that across the same contacts that the power button presses. Probably the easiest / fastest / cheapest thing (especially using my "remote media controller" program I've got partially built...would let the server remote serial commands to this device through the network...I know I could "get" something that would do this...but hey, building it is 1/2 the fun...right!?)
BUT you do make a good point...I could just tie that into the relay that provides the power to the monitor. Probably a cleaner solution, as I KNOW if there is power or not...where my method I'm just toggling the state...
Although...I could read the state by tying the power latch into the mate to DTR...RTS - Requet To Send. They are just regular I/O signals (passed over Serial Voltage Levels...so with this "Nokia" thing being 3.3v TTL, might not need voltage translators...but we'll see).
Found out there are differences in JTAG cables.
You are not kidding. I deal with them in my day-job. I have 6 or 7 of them. There's a ROUGH standard...and realistically speaking...we are not using a JTAG cable. These "serial" programmers are just boot loader cables. JTAG DOES do what you suggest...holding the chip in a halted state, but it does it with hardware lines, not "diverting" the bootloader as you are suggesting. Ehh...it does the job, so I don't want to pick a fight about semantics.
Historicallly I've only known it to be a serial cable - like the one you bought. The little CPU boots up and you interrupt the boot process and you are at a prompt. It works well with the Seagate. BUT there's another JTAG device which uses voltage or ground pins in connection with the serial cables. This lets you get into the computer if there is no bootloader by breaking the CPU boot process, do a couple of memory writes back to the memory. A bit more to it than I wanted to know.
yeah, the typical "standard"
Finished the setup on the micro SD card - only thing is that it keeps defaulting to booting the Dockstar. I do see it reading a bit from the MicroSD just not booting. I've read of issues relating to timing and such about booting off SD. It worked with the notebook/USB drive thing.
Here's what my reads look like (slow).
Pogoplug:/bin$ hdparm -tT /dev/sda
/dev/sda:
Timing buffer-cache reads: 970 MB in 3.00 seconds = 323.05 MB/sec
Timing buffered disk reads: 18 MB in 3.04 seconds = 5.92 MB/sec
Pogoplug:/bin$
Pogoplug:/bin$
Doesn't seem too slow. What did you do to get that speed reading? I'd like to see what my thumbdrives are reading.
Thanks!
--Dan
